Home > Maintenance & Modifications > Swing away spare wheel
jk3528
Has anyone got any pics of one that will fit on a 2006 sport
My new boots mean the spare won’t go where it should
Post #630108 Sat Jan 21 2023 6:32pm
jk3528
Ok looks like I’ll have to make one then will let you see when it’s done
Post #630127 Sun Jan 22 2023 1:54pm
Stevepd
Any pictures of your new boots?. I've never seen a swing away spare on a RRS. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #630128 Sun Jan 22 2023 4:00pm
garrycol
Australia
A D3 swing away will fit but a swing away on a RRS looks disgusting. Try deflating the spare and carrying a air compressor - what storing in the cargo area? Plenty of options which are better than a swing away. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #630137 Mon Jan 23 2023 1:53am
What wheels / tyres are you running that you can't fit the spare in? With larger combinations, it's usually necessary to feed the spare in in a certain way - I have to do that with the 255/55/19 on mine, for example. 2012 SDV6 - it's missing a couple of cylinders
Post #630138 Mon Jan 23 2023 10:18am
jk3528
I have 255/70/18 on new defender white steels so 32.1” rolling dia
Your 255/55/19 are 28.7” you can just get a 255/60/18 under neath which are 30”
Post #630139 Mon Jan 23 2023 10:26am
jk3528
Post #630140 Mon Jan 23 2023 10:27am
garrycol
Australia
I have 265/60R18s which are 30.6" and they fit no issues at all with room to spare - your 32"wheels and tyres should fit if deflated. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #630141 Mon Jan 23 2023 1:47pm
Do you get rubbing when lock is applied? And what tyre have you fitted? 2012 SDV6 - it's missing a couple of cylinders
Post #630147 Mon Jan 23 2023 5:53pm
peterjj
Australia
I was thinking about one of these https://outbackaccessories.com.au/wheel-carriers/landrover/ but look really weird side on.
I think a few people make towbar mounted ones but can't find link at the moment. Pete
2008 L320 TDV8
2022 Hilux Rugged-X
Post #630163 Mon Jan 23 2023 11:17pm
peterjj
Australia
I did have 265\60R18 Bridgestone dueler A/T 697 fitted and they fitted in the spare wheel spot under the car. Very occasionally rubbed when turned tight and suspension well compressed (rock crawling). Pete
2008 L320 TDV8
2022 Hilux Rugged-X
Post #630164 Mon Jan 23 2023 11:23pm
jk3528
They fill the arches better now
As for the 265/55/18 they are wider but still only 30” dia
These are 32.1
Post #630221 Wed Jan 25 2023 11:14am
Wow, I expected big knobbly mud pluggers, not road tyres. Shocked 2012 SDV6 - it's missing a couple of cylinders
Post #630225 Wed Jan 25 2023 2:51pm
jk3528
To be honest these are the standard defender tyres which for what landing I do I have found the traction control and road tyres fine maybe when these have worn down I might put something more aggressive on it’s all about the extra inch of ground clearance that matters
Post #630237 Wed Jan 25 2023 7:42pm
If you can get away with a more road-biased tyre then may as well go with that. It'll give you a nicer drive compared to mud-pluggers that's for sure. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #630259 Thu Jan 26 2023 10:48am
