![]() | Home > Maintenance & Modifications > Swing away spare wheel |
jk3528 Member Since: 30 May 2021 Location: stoke on trent Posts: 75 ![]() ![]() |
Roughly tacked up don’t know why the pics seem to be rotated
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
Presumably you've had to disable the rear parking sensors as part of this project. 2012 SDV6 - it's missing a couple of cylinders
There’s just one that I’m going to move into the horizontal box |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 ![]() ![]() |
Sorry but that looks absolutely awful and really not necessary - however I do accept it is your car and you are free to do what you want. 07MY RRS TDV6
Spare is too big to go underneath the back where it should if I had a roof rack it could go up there but that would cause height issues in some car parks
I'd have thought it would need some beefing up as the spare is heavy and any bouncing is going to put a lot of bending moment through it. As you say, after some off roading you'll have a better idea. 2012 SDV6 - it's missing a couple of cylinders
There is a vertical bar that sits on the cross bar which holds the weight and locks it in place
