Home > Maintenance & Modifications > Only Normal Height Available fault has started to appear |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 948 |
I've got a similar issue and I'm sure it's the battery at fault,, Just in the process of changing it 2010 RRS, TDV8
Sat Dec 31 2022 6:22pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
I've had this before and it was the battery. 2006 2.7 TDV6 HSE in Cairns Blue. |
Sun Jan 01 2023 10:02am |
Josh95 Member Since: 08 Dec 2021 Location: Belfast Posts: 49 |
Having to get a new compressor replaced under warranty. But it’ll be two weeks before the mechanic will be able to see it. Is the car still ok to drive? It’s noticeably lower now as no air is pumping into it at all. |
Fri Jan 06 2023 7:50pm |
Josh I'd be inclined not to, others may say yes. 2006 2.7 TDV6 HSE in Cairns Blue. |
Fri Jan 06 2023 8:19pm |
