Home > Maintenance & Modifications > Only Normal Height Available fault has started to appear
Josh95
Northern Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Java Black
Fault has started to appear on every startup. Car does not let me go into access or off road height. I can hear the compressor running for a few seconds then it cuts off before the fault appears.
The compressor was replaced in August - I doubt I need a new one already from reading previous posts about needing a new compressor?
Has anyone else has the same issue?
Calling the Indy that fitted the new compressor later on this week. Have had no issues with the air suspension until now.
Post #629533 Sat Dec 31 2022 5:49pm
gogsy1956
I've got a similar issue and I'm sure it's the battery at fault,, Just in the process of changing it 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #629534 Sat Dec 31 2022 6:22pm
Stevepd
I've had this before and it was the battery. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #629544 Sun Jan 01 2023 10:02am
Josh95
Having to get a new compressor replaced under warranty. But it’ll be two weeks before the mechanic will be able to see it. Is the car still ok to drive? It’s noticeably lower now as no air is pumping into it at all.
Post #629691 Fri Jan 06 2023 7:50pm
Stevepd
Josh I'd be inclined not to, others may say yes. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #629693 Fri Jan 06 2023 8:19pm
