![]() | Home > Technical > Headlamps set too high |
Dc191peter Member Since: 19 Sep 2022 Location: Bodmin Posts: 7 ![]() ![]() ![]() |
Hi all. My RRS has HID lights with the H7 main beam addition. Dipped beam is perfect and I don’t want to alter it, but the H7 element of the main beam is way too high. My local RR specialist said that the lamps are not adjustable individually which seems rather odd. Is this the case or can I set just the H7 beams a bit lower?
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
These are the actual headlamp adjusters, don't think you can you can adjust main and dip separately externally at least. Are the main beam bulbs fitted/located correctly?
