Home > Technical > Headlamps set too high
Dc191peter
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Hi all. My RRS has HID lights with the H7 main beam addition. Dipped beam is perfect and I don’t want to alter it, but the H7 element of the main beam is way too high. My local RR specialist said that the lamps are not adjustable individually which seems rather odd. Is this the case or can I set just the H7 beams a bit lower?
Edit: photos attached showing main/dipped beam
 2013 RRS HSE Black Edition
Post #628374 Sun Nov 20 2022 8:59pm
These are the actual headlamp adjusters, don't think you can you can adjust main and dip separately externally at least. Are the main beam bulbs fitted/located correctly?
No. 9. Vertical Adjuster
No. 13 Horizontal Adjuster
Post #628375 Sun Nov 20 2022 9:12pm
You can't adjust the beams individually - the whole unit moves as a piece.
I have the same thing on mine and have decided the dipped beam being "long" is more important than the main beam being a bit lower. 2012 SDV6 - it's missing a couple of cylinders
Post #628399 Mon Nov 21 2022 4:13pm
