Home > In Car Electronics > Apple Play in a RRS 2010 ?
AIJ 615
Hi folks
I’ve currently got the ‘Invery’ Bluetooth connector inside my RRS 2010 which is ok and I can stream my music etc however has anyone managed to get apple play in their RRS 2010
I’m sure it can be done but how ? Is there a similar device ?
Alan
Post #628251 Mon Nov 14 2022 9:34pm
Kouze59
France 2010 Range Rover Sport TDV8 HSE Santorini Black
Hello, yes, it's possible
https://www.rrsport.co.uk/forum/topic60080.html
Post #628257 Tue Nov 15 2022 11:54am
AIJ 615
How ? Please tell me a simple plug n play hehe ?
Al
Post #628267 Tue Nov 15 2022 9:04pm
Kouze59
Not really plug & play : I have installed the module sold by Unique Auto Developments. It requires the screen to be removed to insert a pcb. the centre console must be removed, I have installed the module in the upper glove box.
Post #628272 Wed Nov 16 2022 10:49am
TheWojtek
Got my unit from Unique Auto Developments and installed today. A couple of remarks:
The center console didn't need to be removed, I did it according to the manual, but it turned out once I removed the screen, the two plugs on the main unit were accessible easily enough and I didn't have to remove the main unit/CD player at all. Removing the centre console took the longest BTW and again - was completely unnecessary for me. Your mileage may vary, though.
The "install the custom doughterboard inside the screen" is by far the most nerve-wracking, as there is some precision involved and the screen assembly consists of numerous metal shields that are held together with a number of small screws.
I routed the microphone cable behind the A-pillar cover and then to the central overhead console so the provided microphone is invisible and in the stock location.
I don't know about RHD, but the manual states there is enough space behind the lower glovebox to hide away the UAD unit. Not the case with a LHD car. I do not want the unit to freely roam inside either glovebox, so while currently it does, I will need to manufacture a plate to hold it on the "ceiling" of the lower glovebox. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #628621 Sun Nov 27 2022 12:28am
I recently fitted one of the idcore units to mine, as it takes less than 5 mins to remove the centre console, I removed that and fitted the unit in there plenty of space, there is a actually plastic shelf there I used to attach it to, just used Velcro plus a cable tie just as a precaution to secure it. Just didn't like the amount of space behind the glovebox or lack of it.
Post #628638 Mon Nov 28 2022 12:32am
TheWojtek
Lovely idea. Will consider that.
BTW @Col and @Kouze59 - are your Carplay screens stretched vertically just a bit ? Enough for the circular icons to not be, ehm, circular? I've seen it on numerous add-on Carplay devices and here it's visible as well. Didn't find any screen sizing options in IDCore unit setup, but perhaps I wasn't looking good enough? Regards etc.,
Wojtek
Post #628645 Mon Nov 28 2022 11:54am
AndyCHO
Australia 2010 Range Rover Sport 3.0 TDV6 SE Ipanema Sand
As far as I can tell none of the circular icons are stretched at all.. Mostly these installations use the original screen and piggy back off using the new smarts...
My installation etc can be seen in this thread
https://www.rrsport.co.uk/forum/topic59236.html
The only issue we have had is that you need to answer the phone from the steering wheel otherwise nobody can hear you... you can make calls from the screen or using voice command though... a bit strange but you get used to it.
Other than that the touch sccreen is a bit slow but it was never really designed for swiping...
Post #628677 Mon Nov 28 2022 10:20pm
To be fair my phone is Android so only use Android Auto, only really wanted it to use either tom tom go or google maps for the navigation side, as latest factory map here is 2017, just as well they don't build to many new roads. Laughing Haven't noticed any distortion of the icon's although mine is the Bosch screen not that should make any difference, as said is a little slow to swipe but no real problem with that.
Post #628678 Mon Nov 28 2022 11:21pm
Googs
Australia 2012 Range Rover Sport Supercharged Autobiography Fuji White
I have one of these units that was for my L322 https://www.navtool.com/land-rover-range-r...aspx...but have sold it, looks fairly basic plug an play, not ripping the dash apart to that extent for the instal.
Post #629282 Mon Dec 19 2022 8:52pm
Link doesn’t work
Post #629293 Tue Dec 20 2022 11:15am
TheWojtek
Try without the ellipsis and "but". Regards etc.,
Wojtek
Post #629295 Tue Dec 20 2022 12:44pm
Googs
Andy K wrote:
Link doesn’t work
Post #629315 Tue Dec 20 2022 6:59pm
jimbg
Still a duff link! Shocked 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #629318 Tue Dec 20 2022 7:32pm
Googs
Try this...damn internet doesn't play properly
Post #629319 Tue Dec 20 2022 7:43pm
