Home > In Car Electronics > Apple Play in a RRS 2010 ?
TheWojtek
https://www.navtool.com/land-rover-range-r...rface.aspx Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #629322 Tue Dec 20 2022 8:55pm
Got annoyed with Aux lead just plugged into jack plug socket under flap in rear of cubby box, so spliced it into harness under centre console. Just used lead that came with kit and cut it to suit, Pins 10 and 11 on grey plug, not sure why but Blue wire matches Red on jack plug and Red matches White just the way the L/R plugs wired I guess but works fine. Tidy and out of the way.
Post #630382 Sat Jan 28 2023 10:08pm
Googs
Australia 2012 Range Rover Sport Supercharged Autobiography Fuji White
Very neat job Col, you wouldn't know you had Navtool in that little area under the cubby box.
Post #630404 Sun Jan 29 2023 5:21pm
Hi Dave, I actually fitted the IDcore unit not they Navtool one, also fitted it in the space under where the climate control panel fits, shame really if the harnesses had been a bit longer would have just about been able to fit under passengers seat.
Post #630412 Sun Jan 29 2023 8:44pm
