Home > Maintenance & Modifications > Rattle under car when covering uneven road (L320 3.0 RRS)
nthor
NOW FIXED it was the centre prop mount
I have a rattle under the car, if I hit an uneven road (broken up tarmac, dropped manhole etc) I get a rattle. It sounds like a spanner dropped and sitting on the undertray (it's not I have taken them off for now) its kind of like a braking back plate rattling but deeper, a bit like exhaust baffles but again deeper, it's more like I would ecpect to hear from loose side steps (i have checked and its not that as well)
I am sure its from the front end but lets not assume just that just i case, bottom arms have been chaged as well.
ARB bushes look ok I can't get any movement in the arm (I don't have ASC) I changed the drop links as had been suggested but was not that.
Does anyone have any ideas about what else to check, I can only hear it when the windows are open.
Thanks in advance
Post #627814 Mon Oct 31 2022 10:25pm
Stevepd
Get in touch with Steve at T&S Norman. Not to far away and will save pinball guessing. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #627819 Tue Nov 01 2022 6:41am
DaftRascal
United Kingdom 2009 Range Rover Sport TDV8 HSE Santorini Black
I had similar issue, however combined with rear bushes being goosed I got under the car and eventually found it to be the rear propshaft!
Noise was similar to as you say a spanner tapping. I described it as something hitting the exhaust pipe. However! The actual cv behind the propshaft centre bearing is in my case the culprit. Prop was a recon one 3 months ago cheap and not very good quality tbh. Original will be refitted this weekend (new centre support bearing fitted) along with two rear upper arms and two front ones.
Post #628038 Tue Nov 08 2022 5:39pm
Googs
Australia 2012 Range Rover Sport Supercharged Autobiography Fuji White
Was this ever fixed, it would upset me a noise like that.
Post #628048 Tue Nov 08 2022 6:14pm
DaftRascal
It will be fixed on Saturday morning. I actually took a video under the car whilst getting the propshaft to replicate the noise.
Was a HUGE relief! It has however prompted me to lookmfor recon box, trans box and possible front and rear diffs as well
as new torque convertor. Be good to have them in stock then it would be a planned overhaul. Car has done 125k miles, its fresh and has been looked after but I'm aware it is
eating into it's lifespan.
Post #628052 Tue Nov 08 2022 7:19pm
DaftRascal
here are two videos in an attempt to show the noise I am/having
Cant work out how to show them here but they are in my gallery[/img]
Post #628053 Tue Nov 08 2022 7:26pm
Googs
It's always good to have spares in stock...i will have a look at those vid's
Post #628054 Tue Nov 08 2022 7:43pm
Googs
Wow that's one sweet Ride my man....love the drott/ Dozer too. Cool
Post #628055 Tue Nov 08 2022 7:50pm
DaftRascal
Thank you! I genuinely love the RR only thing just now I'd replace it for would be a 4.2 or 5.0SC one 😂 Yeah been operating dozers for few
years now. Actually really enjoy it, prob not many people can say that 18-ish years into a job!
Post #628066 Wed Nov 09 2022 12:17pm
Googs
I have a soft spot for Dozers, Excavators and the like as i've been repairing and Painting them for the past 20 odd years.
I have also just brought a RRS 5.0 SC but haven't had it long enough to say what it's like only it is very quick on acceleration. Cool
Post #628088 Wed Nov 09 2022 9:42pm
Azz3r1989
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Java Black
Hey mate think I have the same sound but couldn’t play your video. Could you possibly send it to me?
Much appreciated 🔥🙏🏻
Post #631569 Sat Mar 11 2023 10:47pm
DOUG_H
posting 3 times so i can pm the op about a similar issue!
Post #632228 Sun Apr 09 2023 9:21pm
DOUG_H
Post #632229 Sun Apr 09 2023 9:21pm
DOUG_H
Post #632230 Sun Apr 09 2023 9:22pm
Azz3r1989
I haven’t received any private message mate?
Post #632231 Sun Apr 09 2023 9:24pm
