![]() | Home > Technical > engine management light |
My money would be on those codes being caused by your manifold blow |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
thanks for that I've got the same feeling going to turn the light off tonight so not on for MOT as any lights on now a failure garage knows it chucked the fault up as told them last night
If it's drawing in enough air to make the fuel adjustment hit the limit (if you can check the long/short term fuel trims in the ECU, I imagine you'll find one bank pegged high), bear in mind it might fail the MOT on the lambda or HC readings.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
I'll get the diagnostic and check the lambada sensor it should pass the emissions test hopefully with out to much agro |
