Home > Technical > engine management light |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
My money would be on those codes being caused by your manifold blow you're probably overfuelling on that bank, despite the code saying otherwise, as it tries to compensate based on incorrect information from the O2 sensor 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Thu Sep 15 2022 1:32pm |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 |
thanks for that I've got the same feeling going to turn the light off tonight so not on for MOT as any lights on now a failure garage knows it chucked the fault up as told them last night
Thu Sep 15 2022 2:43pm |
If it's drawing in enough air to make the fuel adjustment hit the limit (if you can check the long/short term fuel trims in the ECU, I imagine you'll find one bank pegged high), bear in mind it might fail the MOT on the lambda or HC readings.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Thu Sep 15 2022 2:52pm |
I'll get the diagnostic and check the lambada sensor it should pass the emissions test hopefully with out to much agro |
Thu Sep 15 2022 3:04pm |
