Home > Maintenance & Modifications > Restricted performance |
Raysunners Member Since: 20 Sep 2021 Location: Liverpool Posts: 14 |
Hi, hoping for some advice, My 2011 sdv6 rrs is going into rp when reaching 2800rpm ,I have scanned for codes and get two, P22D3 and P22CF, which points to turbo shut off valve, I have tested with a vacuum pump and it opens and shuts, had smoke test carried out they said manifolds ok but egr is leaking. Could the egr cause this fault? Or should I be looking elsewhere , thanks in advance for any advice |
Wed Sep 07 2022 3:43pm |
NoExpert Member Since: 28 Jan 2022 Location: PoznaĆ, Poland Posts: 460 |
Did you vacuum test the solenoid or the vacuum line? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Thu Sep 08 2022 5:25am |
Yes did as much checking with a vac pump as I could, going to try and get a solenoid see if it works not really sure how to test the one that's fitted, any idea? |
Thu Sep 08 2022 2:15pm |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
12v across it and listen for a clunk..
Thu Sep 08 2022 5:26pm |
Yes two wires will try, thanks |
Thu Sep 08 2022 5:46pm |
Update, found a break in the vacuum pipes near back of engine where three pipes join, wasn't sure if I caused the break by pulling them apart but fitted new t piece and so far so good!! No red triangle and loads of power again, thanks to the people who offered advice and I hope this post will help others in the future |
Sat Sep 10 2022 3:44pm |
