Home > Maintenance & Modifications > Restricted performance
Raysunners
United Kingdom 2011 Range Rover Sport SDV6 Autobiography Sumatra Black
Hi, hoping for some advice, My 2011 sdv6 rrs is going into rp when reaching 2800rpm ,I have scanned for codes and get two, P22D3 and P22CF, which points to turbo shut off valve, I have tested with a vacuum pump and it opens and shuts, had smoke test carried out they said manifolds ok but egr is leaking. Could the egr cause this fault? Or should I be looking elsewhere , thanks in advance for any advice
Post #626491 Wed Sep 07 2022 2:43pm
NoExpert
Did you vacuum test the solenoid or the vacuum line? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #626507 Thu Sep 08 2022 4:25am
Raysunners
Yes did as much checking with a vac pump as I could, going to try and get a solenoid see if it works not really sure how to test the one that's fitted, any idea?
Post #626524 Thu Sep 08 2022 1:15pm
aaronjb
12v across it and listen for a clunk..
Disclaimer: I don't actually know which part you're looking at, but that's how I'd test any solenoid - assuming it only has 2 pins, of course! Smile 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #626526 Thu Sep 08 2022 4:26pm
Raysunners
Yes two wires will try, thanks Thumbs Up
Post #626527 Thu Sep 08 2022 4:46pm
Raysunners
Update, found a break in the vacuum pipes near back of engine where three pipes join, wasn't sure if I caused the break by pulling them apart but fitted new t piece and so far so good!! No red triangle and loads of power again, thanks to the people who offered advice and I hope this post will help others in the future Razz Razz
Post #626560 Sat Sep 10 2022 2:44pm
