Home > Technical > Not starting - urgent request for help please
Mavman
I ran out of fuel yesterday in my 2006 SC coming back from Cornwall.
I added 10l from a can to get to the petrol station, however it still would not start.
On several attempts it has started and revved for a few seconds, though mostly it cranks and fails to catch.
Please could someone give me some trouble shooting pointers?
Thanks.
Post #626391 Sat Sep 03 2022 1:27pm
I do recall reading something about using the Gap diag tool if you have one, to prime the fuel pump and injectors on the petrol engines to clear air from system and prime with fuel, I don't know if this would be relevant and need to be done if you had only ran out of petrol, or only if you had actually replaced a components, may be dependant on if you ran the system completely dry or not.
Post #626404 Sat Sep 03 2022 10:14pm
Mavman
Thanks Col. I don't have a diag tool, though I have been following various advice to purge the air from the fuel line without success.
The topic is something of a rabbit hole. Various websites suggest there is a fuel cut off (inertia switch) that can be reset, although I have no idea where to find it. Any suggestions?
Thanks
Post #626422 Sun Sep 04 2022 3:24pm
Not sure may be behind the driver side front footwell panel but only a guess as picture may not even be a sport might be thinking of my old P38. W/shop manual does refers to it but doesn't actually show where it is located, or any procedure for resetting either pressing it or via the ignition/throttle pedal that I can see, although it does on my keyless start facelift s/c.
Post #626443 Sun Sep 04 2022 10:27pm
