Home > Faults & Fixes > Reduced Performance issue |
Rev1Richie Member Since: 26 Aug 2022 Location: Royston, Herts Posts: 6 |
Hi New here so here goes, I got a reduced performance come up and limped home (i knew it did it just wanted to make it happen) When i returned to look at the error codes to figure out what the issue was, when i looked i had the following codes
Fri Aug 26 2022 12:28pm |
Sorry just adding some thoughts from when i owned a BMW, In the BMW if it registered a misfire it would cut the fuel to that cylinder, all you had to do was stop, and restart and drive away quickly warming up the cylinder thus preventing the injector issue.
Fri Aug 26 2022 12:35pm |
