Home > Faults & Fixes > Reduced Performance issue
Rev1Richie
United Kingdom 2005 Range Rover Sport Supercharged Chawton White
Hi New here so here goes, I got a reduced performance come up and limped home (i knew it did it just wanted to make it happen) When i returned to look at the error codes to figure out what the issue was, when i looked i had the following codes
P0308
P0316
P0480
P0051
P0504
I know what these refer to but are these individually or collectively responsible for the reduced engine performance.
I have a question about Diag tools but will sort that out later.
Thanks
Post #626288 Fri Aug 26 2022 12:28pm
Rev1Richie
Sorry just adding some thoughts from when i owned a BMW, In the BMW if it registered a misfire it would cut the fuel to that cylinder, all you had to do was stop, and restart and drive away quickly warming up the cylinder thus preventing the injector issue.
Does the RRS have a similar function ?
Post #626289 Fri Aug 26 2022 12:35pm
