Home > Technical > RRS L320 towing electrics & trailer programming
AutobiographyX2017
Hi all, a bit of a question, on my 2013 L320 we have had fitted a dedicated PF Jones 13 pin trailer electrics, I feared the caravan I purchased had LED lights & would cause problems but the lights seems to function properly and the trailer light lights up when indicating on the dashboard. However the rear parking sensors are not cancelling on reversing, does anybody know whether that’s just the way they are or does the car need programming? I’m also concerned the trailer stability control may not be functioning if not programmed. A lot of people say they don’t need programming I just wondered whether anybody had a definitive answer…..? Thanks 😁
Post #626210 Sun Aug 21 2022 11:35am
Brian Considine
I have an earlier L320 & have had "odd" issue with my trailer lighting which is completely LED.
I've fitted relays & load resistors to the indicator circuits in the trailer to "fool" the electronics that there is a trailer attached.
All you need is a couple of load resistors (cheaper on eBay than many other places) & a couple of 12v 3 pin relays, some connectors, a few short bits of cable & a little time.
The electronics sense the load on the indicators when a trailer/caravan is attached & turn off the rear sensors - you make see the indicators on the trailer/caravan pulse every second or so, especially in the dark.
If you need a diagram then please let me have your email via pm & I'll send you one.
Hope this helps.
Post #626211 Sun Aug 21 2022 12:27pm
You are right to suspect it needs programming.
As a test you could hook up the caravan.
Start engine
Select off road height. If it starts raising then the computer hasn’t accepted it’s got a trailer.
Press down before it gets too high
Post #626212 Sun Aug 21 2022 12:44pm
Brian Considine
Hope this helps.
Further to the above if the trailer light indicator is flashing that means something is acknowledging that there is a trailer attached. However, on my earlier car odd things happened (like the LED's pulsing as the bulb monitoring operated) until I installed the load resistors & relays.
Post #626216 Sun Aug 21 2022 3:24pm
This is a screenshot from the fitting instruction for the L/R (VPLST0071) 13pin towing harness for a MY12/13, the last picture would indicate that it does need programming to do something. When I fitted the kit to mine If I remember right just went into the CCF files and told it that it had tow bar/hitch fitted, but it was a long time ago.
Post #626219 Sun Aug 21 2022 8:53pm
AutobiographyX2017
Hope this helps.
Thanks, I have purchased a Canbus LED adapter but I haven’t used it as the lights were ok & didn’t want to break the seal in case I sent it back. I will probably open it anyway & give it a try 👍🏻
Post #626223 Mon Aug 22 2022 10:13am
AutobiographyX2017
Start engine
Thanks I will give it a try 👍🏻
Post #626224 Mon Aug 22 2022 10:17am
AutobiographyX2017
Thanks, all very helpful, hopefully I can sort it now…….cheers! 😁
Post #626225 Mon Aug 22 2022 10:20am
aaronjb
Start engine
Didn't realise the tow coding altered how the air suspension behaves!
I think the worst part is not disabling the reversing sensors though .. beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep Laughing Compounded by the fact that I take about 20 attempts to back my tiny trailer in anywhere.. Whistle 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #626227 Mon Aug 22 2022 10:39am
If you press the P button you can turn them off manually.
Post #626228 Mon Aug 22 2022 12:35pm
aaronjb
Yep that's what I do at the moment .. I found that every time I went between R & D they would come back on, though (see comment about being crap at backing a trailer in anywhere! Laughing ) which did not help the pressure Mr. Green 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #626229 Mon Aug 22 2022 1:57pm
