![]() | Home > Technical > RRS L320 towing electrics & trailer programming |
AutobiographyX2017 Member Since: 13 Jul 2022 Location: Preston Posts: 12 ![]() ![]() |
Hi all, a bit of a question, on my 2013 L320 we have had fitted a dedicated PF Jones 13 pin trailer electrics, I feared the caravan I purchased had LED lights & would cause problems but the lights seems to function properly and the trailer light lights up when indicating on the dashboard. However the rear parking sensors are not cancelling on reversing, does anybody know whether that’s just the way they are or does the car need programming? I’m also concerned the trailer stability control may not be functioning if not programmed. A lot of people say they don’t need programming I just wondered whether anybody had a definitive answer…..? Thanks 😁 |
You are right to suspect it needs programming.
Brian Considine Member Since: 26 Mar 2022 Location: SE UK Posts: 93 ![]() ![]() |
Further to the above if the trailer light indicator is flashing that means something is acknowledging that there is a trailer attached. However, on my earlier car odd things happened (like the LED's pulsing as the bulb monitoring operated) until I installed the load resistors & relays. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
This is a screenshot from the fitting instruction for the L/R (VPLST0071) 13pin towing harness for a MY12/13, the last picture would indicate that it does need programming to do something. When I fitted the kit to mine If I remember right just went into the CCF files and told it that it had tow bar/hitch fitted, but it was a long time ago.
Thanks, I have purchased a Canbus LED adapter but I haven’t used it as the lights were ok & didn’t want to break the seal in case I sent it back. I will probably open it anyway & give it a try 👍🏻 |
Thanks I will give it a try 👍🏻 |
Thanks, all very helpful, hopefully I can sort it now…….cheers! 😁 |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
Didn't realise the tow coding altered how the air suspension behaves! I think the worst part is not disabling the reversing sensors though .. beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep ![]() ![]() |
If you press the P button you can turn them off manually. |
Yep that's what I do at the moment .. I found that every time I went between R & D they would come back on, though (see comment about being crap at backing a trailer in anywhere! |
