Home > General > Good grief creak creak..
Themoog
United Kingdom 2005 Range Rover Sport Supercharged Rimini Red
Wtf. When my l320 supercharged is driven for a while in warm dry weather the suspension starts to creak like nothing else. It’s a right Beamer driving through towns…
I’ve doused as many rubber joints as I can find with silicone spray but it still won’t shut up. Today I noticed two more joints that I can see inside the rear from above the rear wheels when on off-road height so I gave them some lube too so let’s see what happens.
What and where are the joints that creak - the noise on mine seems to be high up at the rear somewhere. Bloody nuisance. Ta.
Post #625825 Tue Aug 02 2022 1:06pm
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Same with mine, going to have to bite the bullet and have the bushes replaced. 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #625827 Tue Aug 02 2022 1:35pm
aaronjb
Almost certainly the anti-roll bar bushes (although could be other suspension bushes, these are the usual culprit) 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #625829 Tue Aug 02 2022 2:29pm
NoExpert
We have an L320 at the shop that the left rear upper knuckle joint is creaking like nobody’s business. Basically if it can move, it can creak. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #625830 Tue Aug 02 2022 4:25pm
Themoog
I may have sorted it. The bushes I mentioned above the rear wheels that I soaked today don’t seem to creak anymore. I’ve got to got into London on Friday so I’ll know for sure as it’s a longer trip.
Post #625831 Tue Aug 02 2022 4:35pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Get a syringe and needle, fill it will oil I used gear oil my self as iv plenty in the garage then inject 1 ball joint at a time. Upper and lower joints on the drop links etc and see how it goes.
Usually are bushes especially in the summer it seems but iv stopped mine creaking recently doing this.
Post #625832 Tue Aug 02 2022 4:42pm
I think those "Knuckle Bushes" are more of a bearing than a bush, lubricating them may help in the short term, but If they are the culprit and worn I think the ideal solution would be replace them.
Post #625839 Tue Aug 02 2022 8:49pm
