![]() | Home > General > Good grief creak creak.. |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 203 ![]() ![]() ![]() |
Same with mine, going to have to bite the bullet and have the bushes replaced. 2018 Telsa MS
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
Almost certainly the anti-roll bar bushes (although could be other suspension bushes, these are the usual culprit) 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
We have an L320 at the shop that the left rear upper knuckle joint is creaking like nobody’s business. Basically if it can move, it can creak. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 ![]() ![]() ![]() |
I may have sorted it. The bushes I mentioned above the rear wheels that I soaked today don’t seem to creak anymore. I’ve got to got into London on Friday so I’ll know for sure as it’s a longer trip. |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
Get a syringe and needle, fill it will oil I used gear oil my self as iv plenty in the garage then inject 1 ball joint at a time. Upper and lower joints on the drop links etc and see how it goes.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 ![]() ![]() ![]() |
I think those "Knuckle Bushes" are more of a bearing than a bush, lubricating them may help in the short term, but If they are the culprit and worn I think the ideal solution would be replace them.
