![]() | Home > Technical > DPF ISSUE |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 213 ![]() ![]() ![]() |
Link to a post on here about this but not sure it answers your question....sorry
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9026 ![]() ![]() ![]() |
Are you sure it doesn't have a DPF fitted? Some 2008 TDV6 could have them fitted. You'd need to physically check to see if there's one there. Or perhaps it's had one removed and a bodge done to fool the ECU and the bodge has now failed causing the error.
Sween23 Member Since: 11 Jan 2022 Location: Lancashire Posts: 10 ![]() ![]() ![]() |
thanks for the reply
Ah, a proper bodge job then. That's a real |
I did an ecu flash with the IId tool and it seems to have solved the problem 👍 |
Good news. |
