Home > Technical > DPF ISSUE
Sween23
United Kingdom 2008 Range Rover Sport TDV6 HSE Rimini Red
DPF ISSUE
Hi all
I've got a really weird one here. I have an early 2008 2.7 tdv6 without a dpf filter and I have a message keep coming up on my dash telling me it's full and to visit dealer.
Any advise would be muchly appreciated
Thanks Arron
Post #624902 Mon Jun 20 2022 8:52pm
skid1963
Link to a post on here about this but not sure it answers your question....sorry
https://www.rrsport.co.uk/forum/post548975.html 2015 L494 SDV6 3.0 HSE Loire Blue
2006 L320 4.2 Supercharged
2009 BMW X5 M-Sport - Gone
2007 L320 2.7TDV6 SE Buckingham Blue - Gone
2011 Jaguar XFS 3.0V6 Diesel - Gone
2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone
2008 BMW X5 M-Sport - Gone
2005 Audi A6 3.2V6 Quattro S-Line - Gone
Post #624904 Mon Jun 20 2022 10:21pm
Are you sure it doesn't have a DPF fitted? Some 2008 TDV6 could have them fitted. You'd need to physically check to see if there's one there. Or perhaps it's had one removed and a bodge done to fool the ECU and the bodge has now failed causing the error.
Or it could be as simple as a dodgy battery causing errors because the volts are getting low. They don't like dodgy batteries, these cars. 2012 SDV6 - it's missing a couple of cylinders
Post #624911 Tue Jun 21 2022 8:44am
Sween23
thanks for the reply
i have checked and it doesn't have a dpf but as you said someone else could have remove and replaced the exhaust system to a standard one.
i bought the car and then realised the screen on the instrument cluster wasn't working. i removed and the previous owner had put tape over disguising the error message of dpf full.
i have an IID tool so just awaiting to hear back from GAP to see if this can be removed from the ecu.
Post #624915 Tue Jun 21 2022 10:28am
Ah, a proper bodge job then. That's a real Censored . Evil or Very Mad 2012 SDV6 - it's missing a couple of cylinders
Post #624925 Tue Jun 21 2022 4:19pm
Sween23
I did an ecu flash with the IId tool and it seems to have solved the problem 👍
Post #624951 Wed Jun 22 2022 11:26am
Good news. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #624954 Wed Jun 22 2022 2:40pm
