Home > Maintenance & Modifications > 07 Supercharged ACE pump & pipes replacement (advice nee
celticbaz
United Kingdom 2007 Range Rover Sport Supercharged Rimini Red
Hi Folks,
In need of some advice please. Have a 07 Supercharged. Ace pump and pipes needed to be replaced. I understand the chassis must be raised to fit the pipes. Second hand pump is fitted, have also replaced alternator and 2x belts whilst in there but I am now considering doing away with the system. I was fully intent on fixing the problem but it's becoming a pain and costs mounting.
I have read conflicting opinions on forums about disabling the system. On both the effect it has on vehicle and the ways this is done. I am not super fussed about the effect on handling etc but certainly want the car to remain safe, not that it get's rallied! I'm keen to understand my options from someone with prior experience here. I assume I have three options at present:
1. Disable/Bypass the ACE system (unsure of everything I would need to complete or buy for the job?)
2. Continue with the pipes replacement next (bought new already) and find someone nearby (car won't drive) good but reasonable to raise the chassis on a two post ramp. Based in Ayrshire, Scotland. Once done, I understand the pump bleeding process can be difficult and requires two pieces of equipment at reservoir and pump sides, although others don't seem to think the job is difficult or needs any such specialist equipment at all - i.e the pump can be hand turned to insure fluid is present and then bled manually.
3. A long shot - cut out the offending leaking middle pipe sections and piece in replacement high pressure pipes and compression fittings. (As someone who has done some domestic plumbing over the years, I would be keen to establish if this is actually viable or just nonsense - some on other forums are adamant this can be done no bother). If it is indeed possible would like to know exactly what to buy.
Thanks in advance
Barry
Ad order: 220517-881
Post #624759 Mon Jun 13 2022 11:13am
ShooterNeil
I am changing my front pipes and will be cutting the new ones to save body lift you can get 400bar fittings from £3 up be careful as the system has a maximum working pressure of 150 bar
I am under the impression from some posts that the system self bleeds but I’m only replacing the front pipes not the whole system 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #624773 Mon Jun 13 2022 7:34pm
daxmatt
Its not that big of a job,you only need to lift the body an inch or so,its possible to do the job with 2 jacks.
It does self bleed,well,mine did anyway.
Don't remove the system,it will ruin the feel of the car.
I took some pics on my thread
Post #624791 Tue Jun 14 2022 7:40pm
celticbaz
Presuming yours was all front end, how did you manage to bleed the pump and pipes to reservoir daxmatt?
Post #624807 Wed Jun 15 2022 3:02pm
celticbaz
I'd be keen to hear or learn more about the fittings you intend to buy? presumably you have bought exact replacement pipes to fit vehicle rather than DIY ones?
Thanks
Post #624808 Wed Jun 15 2022 3:04pm
ShooterNeil
£4.50 each from local hydraulic pipe replacement place 61 AB 5.0 supercharged rocket
Post #624813 Wed Jun 15 2022 5:32pm
daxmatt
I just filled it up,and topped it up a few times,never bled anything
Post #624818 Wed Jun 15 2022 8:17pm
celticbaz
What diameter pipe do they fit in mm? so I know to ask for the right thing cheers
Post #624828 Thu Jun 16 2022 1:46pm
ShooterNeil
10 mm 61 AB 5.0 supercharged rocket
Post #624861 Sat Jun 18 2022 4:56pm
ShooterNeil
Pipes on
Then I broke the spout on the reservoir so got to get a new one 61 AB 5.0 supercharged rocket
Post #624862 Sat Jun 18 2022 5:03pm
celticbaz
H ShooterNeil, apologies for late reply.
I've had a few other things to deal with so this hasn't been at the top of my agenda for a while, back on the case now though.
That looks like a tidy job, well done. I take it all is sorted now?
I'd be keen to have a quick chat with you over the phone if you wouldn't mind? I've pieced in my replacement pipes and at the refilling the system stage. Opinions on how or what should be used to accomplish this properly vary massively. I'm keen to avoid buying the bleeding bottle £300 and control box at another approx £300 but certainly don't want to fry the new pump if not bled properly. Your insight or anyone else's with experience of this for that matter would be much appreciated, thanks.
Regards
Barry
Post #626255 Wed Aug 24 2022 7:52am
