Home > Maintenance & Modifications > 07 Supercharged ACE pump & pipes replacement (advice nee |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 |
I am changing my front pipes and will be cutting the new ones to save body lift you can get 400bar fittings from £3 up be careful as the system has a maximum working pressure of 150 bar
Mon Jun 13 2022 7:34pm |
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 154 |
Its not that big of a job,you only need to lift the body an inch or so,its possible to do the job with 2 jacks.
Tue Jun 14 2022 7:40pm |
celticbaz Member Since: 17 May 2022 Location: Scotland Posts: 7 |
Presuming yours was all front end, how did you manage to bleed the pump and pipes to reservoir daxmatt? |
Wed Jun 15 2022 3:02pm |
I'd be keen to hear or learn more about the fittings you intend to buy? presumably you have bought exact replacement pipes to fit vehicle rather than DIY ones? Thanks |
Wed Jun 15 2022 3:04pm |
Wed Jun 15 2022 5:32pm |
I just filled it up,and topped it up a few times,never bled anything |
Wed Jun 15 2022 8:17pm |
What diameter pipe do they fit in mm? so I know to ask for the right thing cheers |
Thu Jun 16 2022 1:46pm |
10 mm 61 AB 5.0 supercharged rocket
Sat Jun 18 2022 4:56pm |
Pipes on
Sat Jun 18 2022 5:03pm |
H ShooterNeil, apologies for late reply.
Wed Aug 24 2022 7:52am |
