Home > Technical > L494 3.0 SDV6 - Intermittently throws loads of fault codes
nick4275
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Driving me nuts at the mo…..
2014 L494 - perfectly ok 98% of the time but will occasionally throw a bucket load of fault codes followed by limp mode.
I’ve got a Gap tool which shows a variety faults from numerous ecu’s.
They all have a common thread - they report invalid data or lost communication.
Resetting codes works ok and everything returns to normal. It then remains ok for a good while.
I’m thinking the fault is caused by a dodgy connection somewhere ? I’ve checked the connections to the main ecu, which look fine.
Has anyone had an issue like this or can anyone point me in the right direction with troubleshooting?
I’m wondering if there are any known issues with maybe water getting into wiring looms ?
Thanks in advance.
Post #624744 Sat Jun 11 2022 11:28pm
jimbg
Have you checked the battery, an iffy battery causes all sorts of problems. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #624746 Sun Jun 12 2022 8:01am
Red Arrow
Re: L494 3.0 SDV6 - Intermittently throws loads of fault cod
Thanks in advance.
Headlight earth strap points, under the wheel arches at each side , Riv Nut and seal and job done Thumbs Up
My drivers side one through up 29 fault codes
Post #624749 Sun Jun 12 2022 10:01am
nick4275
Thanks for the quick replies both.
Red Arrow, you are indeed a star of the brightest magnitude !!
Whipped off the the arch liners this morning - more white fluff on the earthing points than you find on a baby polar bear !!
Earth points replaced, leads cleaned and the whole lot sealed
Guess how many fault codes I have now........
Zero !!
Thanks a million for the advice !
Post #624762 Mon Jun 13 2022 1:47pm
Red Arrow
The beers are on you next time I am in Bewdley Thumbs Up
Post #624770 Mon Jun 13 2022 5:51pm
pjbracer1
Old post but anyone got and pictures or process of these earth points in the wheel arches? A mate is having the same issue, I do occasionally get a low bat warning even though I know its full and left on a CTEC, so the BMS must think there is something going on.
Just thought if I new how to do it I could do both at same time
cheers
P If a jobs worth doing, get a someone who knows what they are doing to do it!
RRS Autobiography Indus
RR P38 HSE V8
RRS Supercharged Santorini
AMG CLK Rear Tyre Shredder
Post #629581 Mon Jan 02 2023 8:31pm
nick4275
Hi there,
Sorry I don't have any pictures and I can't take any more as my L494 was stolen a couple of months ago !
It's an easy and obvious fix though.
Take off the front wheel and remove the wheel arch liner - its clipped in so its no big deal
Look at the suspension turret and then look inside the arch towards the front of the vehicle.
You'll soon see a couple of black wires that are crimped into one connector thats bolted to the body.
Mine was severely corroded, in fact the mounting stud snapped off as i tried to remove the bolt.
No great pain as there is another bolt a couple of cm's away. You can easily attach the crimp connector to it.
Replace the crimp connector if it looks at all suspect.
Don't forget to do both sides of the vehicle !
It transformed my life instantly as mine was throwing faults left right and centre. Afterwards there was not a fault to be seen !
Good Luck ! Normally found lying under one of these:
2014 L494 3.0L SDV6 Santorini Black
2007 L322 3.6L TDV8 Gunmetal Grey
Post #629598 Tue Jan 03 2023 1:02pm
Disco_Mikey
Not the best of pictures, but circled here Thumbs Up
Post #629603 Tue Jan 03 2023 3:32pm
pjbracer1
Awesome cheers guys now to try and get the wheels off! Damn wind guns make it hard work at home! If a jobs worth doing, get a someone who knows what they are doing to do it!
RR P38 HSE V8
Post #629609 Tue Jan 03 2023 6:15pm
