![]() | Home > Technical > L494 3.0 SDV6 - Intermittently throws loads of fault codes |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1856 ![]() ![]() |
Have you checked the battery, an iffy battery causes all sorts of problems. 2023 P440e SE Dynamic on order -cancelled
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 590 ![]() ![]() |
Headlight earth strap points, under the wheel arches at each side , Riv Nut and seal and job done ![]() My drivers side one through up 29 fault codes |
nick4275 Member Since: 18 Feb 2022 Location: Bewdley Posts: 4 ![]() ![]() ![]() |
Thanks for the quick replies both.
The beers are on you next time I am in Bewdley |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 ![]() ![]() |
Old post but anyone got and pictures or process of these earth points in the wheel arches? A mate is having the same issue, I do occasionally get a low bat warning even though I know its full and left on a CTEC, so the BMS must think there is something going on.
Hi there,
Not the best of pictures, but circled here |
Awesome cheers guys now to try and get the wheels off! Damn wind guns make it hard work at home! If a jobs worth doing, get a someone who knows what they are doing to do it!
