![]() | Home > Maintenance & Modifications > Underbody surface rust.... looking for recommendations |
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 213 ![]() ![]() ![]() |
Hi can’t recommend Lanoguard enough excellent quality ,easy to use spreads well and you can get a pack that contains a tub of there fantastic grease to use also on exposed bolts for extra protection.Great product I fine much better than Waxoyl that I previously used. |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
I second Lanoguard. Easy to apply yourself. Can do the whole underside in an hour or less. I had Dinitrol applied to my last Sport but found it horrible to work on underneath once it was applied, it’s like a tar. Lanoguard is lighter, can be done at home, contains all natural ingredients (no petroleum based chemicals) and is a UK family owned business with excellent support. For £70 you can do the whole underneath and have plenty left over. 2016 RRS SVR Estoril Blue
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 252 ![]() ![]() |
How long does Lanoguard last in real world use? MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green) |
Hi I have had it nearly 15 months and went under and checked last week I only had a minimal touch up to do ,I think Lanoguard recommendation is to check yearly . |
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 701 ![]() ![]() ![]() |
Cheers everyone ,lanoguard sounds good , what preparations did yous make to your vehicles before applying it , did you wire brush and did you have to use some kind of rust killer too before the lanoguard ? Java black 2006 |
HI yea did a bit prep with. wire brush Lanoguard can be sprayed onto surface rust with no issues and doesn't require a highly prepped and keyed up surface. The lanolin will be attracted to the metal underneath and slowly push off any existing rust. |
That’s great Thankyou , think il give it a go this weekend , I’ve got a set of Ramps il drive it up onto and slide under Java black 2006 |
Cheers yeah I did think it will be a messy job Java black 2006 |
It’s worth getting the Lanoguard pack with the grease included also |
