Home > Maintenance & Modifications > Underbody surface rust.... looking for recommendations
Kensta
Hi , mines just been serviced and I was advised there is surface rust coming through on the underbody so I want to tackle this
Can anyone recommend a good DIY rust treatment / underseal for our cars ?
And what’s the rough price of getting it done professionally? North east area Thumbs Up
Thanks Java black 2006
Post #624623 Fri Jun 03 2022 9:04am
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi can’t recommend Lanoguard enough excellent quality ,easy to use spreads well and you can get a pack that contains a tub of there fantastic grease to use also on exposed bolts for extra protection.Great product I fine much better than Waxoyl that I previously used. Thumbs Up https://www.lanoguard.co.uk
Post #624624 Fri Jun 03 2022 12:06pm
Scrumpy
I second Lanoguard. Easy to apply yourself. Can do the whole underside in an hour or less. I had Dinitrol applied to my last Sport but found it horrible to work on underneath once it was applied, it’s like a tar. Lanoguard is lighter, can be done at home, contains all natural ingredients (no petroleum based chemicals) and is a UK family owned business with excellent support. For £70 you can do the whole underneath and have plenty left over. 2016 RRS SVR Estoril Blue
Post #624625 Fri Jun 03 2022 12:22pm
RRT
How long does Lanoguard last in real world use? MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green)
Post #624627 Fri Jun 03 2022 2:36pm
Iomegas
Hi I have had it nearly 15 months and went under and checked last week I only had a minimal touch up to do ,I think Lanoguard recommendation is to check yearly . Thumbs Up
Post #624628 Fri Jun 03 2022 3:43pm
Kensta
Cheers everyone ,lanoguard sounds good , what preparations did yous make to your vehicles before applying it , did you wire brush and did you have to use some kind of rust killer too before the lanoguard ? Java black 2006
Post #624642 Sun Jun 05 2022 1:00pm
Iomegas
HI yea did a bit prep with. wire brush Lanoguard can be sprayed onto surface rust with no issues and doesn't require a highly prepped and keyed up surface. The lanolin will be attracted to the metal underneath and slowly push off any existing rust. Thumbs Up
Post #624643 Sun Jun 05 2022 2:07pm
Kensta
That’s great Thankyou , think il give it a go this weekend , I’ve got a set of Ramps il drive it up onto and slide under Java black 2006
Post #624668 Mon Jun 06 2022 9:11pm
Iomegas
Thumbs Up Enjoy one thing I would make sure is you have some eye protection on if I was you if your outside it can carry easily .
Post #624685 Tue Jun 07 2022 7:10pm
Kensta
Cheers yeah I did think it will be a messy job Java black 2006
Post #624693 Tue Jun 07 2022 10:43pm
Iomegas
It’s worth getting the Lanoguard pack with the grease included also Thumbs Up you may even get good weather to do it lol like you I’m in North East also so weather can be a bit unpredictable Big Cry Big Cry
Post #624701 Wed Jun 08 2022 6:15pm
