Home > In Car Electronics > Rear Seat Headphones - No Screens?
Sit
United Kingdom 2012 Range Rover Sport SDV6 HSE Firenze Red
Back to the market looking for a ‘12/‘13 plate RRS Luxury/Red/Black Edition, a number of cars for sale have the bulbous roof mounted pod with IR sensors suggesting there are headphones/rear media but no screens in the headrests????
Can anyone advise what the purpose of having headphones in the back is if you don’t have screens?
Assuming someone is going to tell me it’s so the passengers can listen to the audio without disturbing others in the car, is it controllable from the rear or does it rely on driver?
Last question in relation to this - if I find a car I like which has this system but headphones are missing can they still be purchased and paired with the OE system??
Si 2012 RRS HSE SDV6 - current
2006 911 Carrera convertible
2016 L200 Barbarian pickup
2010 RRS Lux
2008 E93 M3
2004 VX220 Turbo Stg 2
2010 E70 X5 30d M Sport
2006 Golf R32
Post #624589 Tue May 31 2022 7:18pm
Yes, you can buy the Headphones separate and they do pair no problem, L/R referred to the original L320 ones as "whitefire" but the later ones from the L494 and Ewock work as well, personally I found the original one's more comfortable but are larger and more cumbersome than the later one's. I do have some sets of each here if you want a picture of the difference.
Are you sure the cars have the infrared transmitter and not the normal alarm sensor module ? the infrared transmitter is the large shinny black part. If the car has the dual view screen which I believe the Black edition did as standard although I think it was a option on all variants, that will have it, as L/R supplied one a set of headphones with the dual view for use by the passenger, if it had dual view and RSE they supplied 3 sets. I can't be certain but I'm inclined to think if rear seat passengers wore them they would simply here the same as front seat passenger, whereas with RSE they can listen/watch different media.
Not sure what you get if you plug say a Ipod into the rear AV sockets though without RSE.
Post #624592 Tue May 31 2022 9:56pm
Sit
Morning Col,
Thanks for the info, that’s really useful thank you. I think the module I have seen is the IR one -
Will bear that in mind when looking, good to know still available and easy to pair.
2010 RRS Lux
2008 E93 M3
2006 Golf R32
Post #624594 Wed Jun 01 2022 7:19am
If the dash has this Dual View button rather than one marked SetUp, I think it would explain why it has the infrared transmitter and no rear screens.
Post #624595 Wed Jun 01 2022 8:00am
Sit
Perfect thanks Col Thumbs Up 2012 RRS HSE SDV6 - current
2010 RRS Lux
2008 E93 M3
2006 Golf R32
Post #624602 Wed Jun 01 2022 5:57pm
