Home > Faults & Fixes > Time and headunit keep resetting
DaviesC
United Kingdom 2005 Range Rover Sport TDV6 HSE Orkney Grey
2005 RRS HSE.
Bit of a weird one. My clock and headunit (cd player / radio) keeps resetting. It usually happens when I unlock the car and put the key in the ignition.
The battery is fully charged.
Any ideas of causes or fixes?
Thanks,
Chris
Post #624438 Sun May 22 2022 6:13pm
thejack
Italy 2012 Range Rover Sport SDV6 HSE Orkney Grey
Hi, check your battery connections, they often become loose and can cause the system to reset. Check them and even if they have a little (to none) play, replace them or put in a shim to get them tight on the battery poles. Good luck.
Post #642140 Wed May 22 2024 6:54am
