![]() | Home > Faults & Fixes > Time and headunit keep resetting |
thejack Member Since: 19 Oct 2022 Location: reggio emilia Posts: 10 ![]() ![]() ![]() |
Hi, check your battery connections, they often become loose and can cause the system to reset. Check them and even if they have a little (to none) play, replace them or put in a shim to get them tight on the battery poles. Good luck. |
