![]() | Home > Technical > RRS L320 black outside door trim |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
If I remember correctly the front door has two of the small torx screws one each end and the rear door just the one, remove the screws and just lever/pull the trim upwards to remove it, if you don't want to reuse the trim just give it a good pull, if you do want to reuse them lever off very carefully as they do bend very easily.
OB42UK Member Since: 28 Jun 2020 Location: Whitchurch, Shropshire Posts: 18 ![]() ![]() ![]() |
Hi Col,
