Home > General > Where is the Engine Number located on a 3.6 TDV8?
DirtBuddha
England 2010 Range Rover Sport TDV8 HSE Galway Green
Ive found the engine number on the little stainless steel plaque that's mounted high up, near the front on the engine near the cam cover, but is there an engine number stamped into the engine block itself - and if so, where can I find it?
Asking because the car is being exported and we need to know....
Post #624210 Wed May 11 2022 1:31pm
Eaters
Copied from a Google search - any help?
Where is the engine number on a Range Rover Sport?
Image result for engine number range rover sport TDV8
Engine number: 2L diesel: The number is located on the top of the engine. V6 diesel: The number is located on the front of the left-side camshaft cover. V8 diesel: The number is located on the top of the engine, on the left side of the inlet manifold.
And from the manual (although this may well be the petrol version?)-
 Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #624215 Wed May 11 2022 2:58pm
DirtBuddha
Thanks, I found the stainless steel tab near the cam cover already but searching for the engine number stamped into teh block is another matter entirely - there is SO MUCH STUFF jammed in there it's almost impossible to see anything!
Post #624218 Wed May 11 2022 6:23pm
OvalAutos
Very rare to actually find an engine number on the block. Most of the time it has corroded and can't be seen.
Just go with the tag on the top of the engine and check your V5C to see if they match. If you PM me your reg number, ,I'll look it up for you. Joe
Post #624259 Sat May 14 2022 8:23am
DirtBuddha
Thanks - PM sent.
Post #624284 Sun May 15 2022 6:08pm
