Home > Maintenance & Modifications > Rear Active Anti Roll Bar
Lynchy
United Kingdom 2007 Range Rover Sport Supercharged HST Java Black
Hi All,
Just had my 07 RRS in for a small oil leak under the rear of the car. Turns out its the Active Anti Roll Bar leaking. Being quoted £2500+ for this.
Do you know if its worth getting a used one?
Post #624121 Mon May 09 2022 2:45pm
Lynchy
Post #624122 Mon May 09 2022 3:04pm
Lynchy
Do i just need the LR024073 part? Ive found one at a garage that has come off a 3.0. Is this just a straight swap?
Post #624123 Mon May 09 2022 3:05pm
Lynchy
If this completely drains of fluid, what is the risk? Reason i ask is its leaking now, but i need to drive it to to pick up the part and then drive it to a garage. Is it safe?
Post #624124 Mon May 09 2022 3:07pm
I'd fit a new OEM bar. £600 plus fitting. At least then you know you're starting with a good item rather than an unknown second hand one.
If the system drains of fluid, the pump won't be happy. If you're picking up your second hand unit from a LR garage, perhaps get them to top up the fluid when you're there as a "get you home".
It's worth noting that a little fluid goes a long way when it's leaking so it can look like a whole bottle of oil has been thrown around where in reality it's probably less than a few spoons full. 2012 SDV6 - it's missing a couple of cylinders
Post #624128 Mon May 09 2022 3:57pm
Lynchy
Thanks mate. Understand the pump will run dry, but is it still safe to drive?
Post #624130 Mon May 09 2022 4:05pm
It'll be rolling around in the corners but if you go gently you should be ok I'd have thought. If the car figures it's unsafe, it'll throw up a red warning light.
How much fluid is left in the reservoir? 2012 SDV6 - it's missing a couple of cylinders
Post #624132 Mon May 09 2022 4:15pm
Lynchy
That was going to be my next question. Where is the tank, and i will keep it topped up for now.
Post #624134 Mon May 09 2022 4:55pm
It's on the left hand side of the engine bay, near the front, and it's got a yellow cap on it. The other yellow cap - over by the coolant header tank - is the power steering reservoir. 2012 SDV6 - it's missing a couple of cylinders
Post #624135 Mon May 09 2022 5:19pm
Lynchy
Just checked there, and its well below the min level (about 1cm). Can you get any ACE fluid?
https://www.amazon.co.uk/Cold-Climate-Flui...amp;sr=8-1
Post #624136 Mon May 09 2022 5:30pm
Disco_Mikey
Re: Rear Active Anti Roll Bar
Lynchy wrote:
Hi All,
We always replace the pipes when doing a rear bar. We're about £900 less than your quote though. Maybe ask for an itemised estimate Thumbs Up
Post #624137 Mon May 09 2022 5:39pm
Lynchy
I'm hearing good things about Lucas Stop Leak Fluid also. Have you heard anything on that as a quick fix?
Post #624139 Mon May 09 2022 5:40pm
Lynchy
Disco_Mikey wrote:
Lynchy wrote:
Hi All,
He said he can do the change for £600 if i supply the Bar. Second hand Bar is around the £200 mark. So looking at £800 now.
Post #624140 Mon May 09 2022 5:42pm
