![]() | Home > In Car Electronics > Media system fault after carwash |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
sounds like water has got into the electronics ...check for water ingress.. |
Scotty1980 Member Since: 08 May 2022 Location: Somerset Posts: 30 ![]() ![]() ![]() |
Hi Scarey,
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1876 ![]() ![]() |
User NAKS has a link to the workshop manual in his signature 2023 P440e SE Dynamic on order -cancelled
Thank you jimbg.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Never got around to bookmarking the document sections yet, but Audio starts around page 87, Component Location page 110.
Cheers Col.
I would give it a good charge first? 2023 P440e SE Dynamic on order -cancelled
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
I wonder what the 74% healthy is supposed to mean. The internal resistance doesn't look bad and the voltage at 12.52V is over 80% charged. I'd be tempted to put it on a smart charger for 24hr just to see if a fully, fully, charged battery still causes the problem with the audio. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Hi RRSTDV8,
These vehicles can be quite sensitive to battery condition and general voltages through the system. It's amazing how something seemingly unconnected can cause problems. For example, I have a small USB device plugged in to the USB socket in the arm rest. Every now and then I find the car throwing up strange errors or the ICE system plays up. Unplug the USB and all is OK again. Leave it a while and plug it back in and it's still all fine. Until the next time - which is usually months away.
Hi RRSTDV8,
Hello all. Short update. The fully charged battery did not solve the fault. I ran the diagnostic tool again and the dab module has several fault codes for L band antenna and band 3 antenna which are intermittent and two that are permanent which just say control module. They are U3000 codes and the antenna faults are B codes. So I’m thinking it’s got to be the antenna on the roof which is the L band and sat nav antenna, plus the dab module potentially.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
I’m not that familiar with the facelift models, however the DAB models can be trouble some.
You could try disabling the DAB radio via the CCF files, whether that would actually prove anything though I wouldn't know, but it might give you a clue of some sort.
