Home > In Car Electronics > Media system fault after carwash |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
sounds like water has got into the electronics ...check for water ingress.. |
Sun May 08 2022 8:27am |
Scotty1980 Member Since: 08 May 2022 Location: Somerset Posts: 30 |
Hi Scarey,
Sun May 08 2022 11:37am |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1843 |
User NAKS has a link to the workshop manual in his signature 2023 P440e SE Dynamic on order -cancelled
Sun May 08 2022 12:12pm |
Thank you jimbg.
Sun May 08 2022 12:21pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5008 |
Never got around to bookmarking the document sections yet, but Audio starts around page 87, Component Location page 110.
Mon May 09 2022 12:39am |
Cheers Col.
Mon May 09 2022 3:12pm |
I would give it a good charge first? 2023 P440e SE Dynamic on order -cancelled
Mon May 09 2022 3:22pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
I wonder what the 74% healthy is supposed to mean. The internal resistance doesn't look bad and the voltage at 12.52V is over 80% charged. I'd be tempted to put it on a smart charger for 24hr just to see if a fully, fully, charged battery still causes the problem with the audio. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Mon May 09 2022 4:13pm |
Hi RRSTDV8,
Mon May 09 2022 9:08pm |
These vehicles can be quite sensitive to battery condition and general voltages through the system. It's amazing how something seemingly unconnected can cause problems. For example, I have a small USB device plugged in to the USB socket in the arm rest. Every now and then I find the car throwing up strange errors or the ICE system plays up. Unplug the USB and all is OK again. Leave it a while and plug it back in and it's still all fine. Until the next time - which is usually months away.
Tue May 10 2022 9:08am |
Hi RRSTDV8,
Tue May 10 2022 9:19am |
Hello all. Short update. The fully charged battery did not solve the fault. I ran the diagnostic tool again and the dab module has several fault codes for L band antenna and band 3 antenna which are intermittent and two that are permanent which just say control module. They are U3000 codes and the antenna faults are B codes. So I’m thinking it’s got to be the antenna on the roof which is the L band and sat nav antenna, plus the dab module potentially.
Wed May 11 2022 1:07pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4992 |
I’m not that familiar with the facelift models, however the DAB models can be trouble some.
Fri May 13 2022 5:55pm |
You could try disabling the DAB radio via the CCF files, whether that would actually prove anything though I wouldn't know, but it might give you a clue of some sort.
Fri May 13 2022 9:18pm |
