Home > Technical > Urgent: One wiper not working!
MallorcaNick
Spain 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Hi all,
I've just spent ages trying to find a topic on here to help me, but can't.
My driver side wiper's not working. The passenger side is fine. It slides up manually when I do it by hand, but not when I try in the normal way.
Does anyone know what it could be? I guess the motor is one obvious option but I don't know how many motors these cars have and whether there's a common issue with the blades 'coming off' the rotor.
I'm going to pop into my local mechanic later today and would love to be armed with some info (ie usual fixes, approximate costs, etc) from you guys.
Edit: RRS TDV6 2011. Battery replaced last week.....ps I live in Spain where it rarely rains, but did today and will tomorrow too!
Thank you so much in advance.....
Post #623557 Wed Apr 13 2022 10:05am
Linkage broken I expect.
Probably best to buy a second hand motor and linkage
Post #623558 Wed Apr 13 2022 11:18am
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
This might help.
 Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #623559 Wed Apr 13 2022 11:36am
MallorcaNick
Thanks for the quick reply, Andy......
What exactly is the linkage please?
Also, don't you think it's possible that it's just slipped off the part that the arm connects to?
Post #623560 Wed Apr 13 2022 11:36am
MallorcaNick
Re: This might help.
BJH1959 wrote:
https://www.youtube.com/watch?v=RBW6yVs-2zA
Thanks Barrie. That was really helpful.
Do you know if it's that easy to get to the mechanical motor part (that they showed was worn in that video) on a 2011 RRS please?
Post #623561 Wed Apr 13 2022 11:47am
BJH1959
Sorry Nick. I don't know. I recall this from when a mate had the same problem. I can do some things myself but relatively speaking I do not have the expertise and knowledge of some people here. Barrie.
Post #623565 Wed Apr 13 2022 2:21pm
If it’s has slipped off once, it’s probably going to slip off again.
To get to it, you have to remove the wiper arms (which can be a pig of a job on these) and then remove the plastic trim
Post #623568 Wed Apr 13 2022 2:40pm
MallorcaNick
Thanks both.
I'll probably have to order a new motor and linkage then? Second hand parts for a 2011 RRS aren't easy to find here in Spain.....
Post #623573 Wed Apr 13 2022 10:17pm
I take it you have checked that the linkage is broken and not something simple like the arm slipping on the shaft spindle due to loose retaining nut or worn taper in the arm, only a thought and costs nothing to check. I would think twice about buying genuine L/R parts if it can be avoided as you are looking at nearly 300 euros for the motor and 200 for the linkage, does not come as a complete assembly. If it's any help to locate the parts the L/R part numbers are Motor LR075581 and Linkage LR038348 assuming the car is L/H/D
Post #623575 Thu Apr 14 2022 12:53am
If new parts you would only want linkage
Post #623576 Thu Apr 14 2022 7:03am
hoppy_70
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Rimini Red
I’ll plus one the wiper arms being a pig to get off. You can get a wiper arm puller from Amazon for little cash. Once off, the scuttle panel is quite easy to get off which will allow you access. You don’t need a motor, just the linkage.
I’d spray/ wd40 where the wiper arm nut is now if I were you. Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Range Rover sport HSE Dynamic P400e Silver
Range Rover Sport 3.0 SDV6 HSE Dynamic 2016 MY
Range Rover sport 3.6tdv8HSE 2007 Gone
Range Rover sport 2.7tdv6SE 2005 Gone
Range Rover sport 2.7tdv6SE 2007 honey
Range rover Vogue 2005 4.4 - GONE and missed
BMW 535d M sport 2006 - GONE not as missed
BMW X5 4.4 2004 sport - GONE
Post #623579 Thu Apr 14 2022 2:15pm
MallorcaNick
Thanks all.
I had a look under the bonnet but there's some water-proofing type of trim that's covering the mechanical system and I'll only break it if I try to remove it.
I'll take the car into my local mechanic tomorrow and suggest that they check the bolt and spindle's looseness before trying to replace any parts unnecessarily.
I really appreciate all your help..........
Post #623736 Thu Apr 21 2022 8:58am
MallorcaNick
Update: Linkage was the problem, apparently, and a new one has been ordered (eventually!). Luckily it doesn't rain often in Spain Smile
€80 + labour seems like a cheap fix, if I'm honest....so thanks all for your amazing help and advice.
Post #623878 Wed Apr 27 2022 10:02am
