Home > Wheels & Tyres > Wheel ?
jk3528
Wheel ?
It appears I have as a spare a wheel that won’t fit my wheel nuts
It’s slightly different to the others
When did they use different types
Post #623124 Sat Mar 26 2022 11:40am
The top one isn't an RRS wheel. 2012 SDV6 - it's missing a couple of cylinders
Post #623126 Sat Mar 26 2022 12:34pm
Top pictures a early 18" 02-09 Fullfat wheel I think, ran those on my old P38.
Post #623138 Sat Mar 26 2022 10:30pm
Tyrefitter
The top one looks like a P38 wheel,the one I had the wheels looked the same & iirc the stud pattern is different. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #623139 Sun Mar 27 2022 3:16am
Stud pattern is the same on the P38, Sport and Fullfat, it is the Wheel Spigot bore which is a different diameter on the P38, along with a smaller shank on the wheel nuts for the 02-09 L322. When I fitted early L322 wheels to my P38 I also used early L322 wheel nuts, and when I fitted Sport wheels I used Sport wheel nuts, along with a spigot ring reducer for both the L322 and Sport wheels.
Post #623140 Sun Mar 27 2022 3:47am
jk3528
Ok so will it fit with different wheel nuts ?
Post #623141 Sun Mar 27 2022 8:49am
I assume the Sport wheel nut shank diameter is to large to fit locate in the hole in the rim, if it is a very early L322 rim you will probably need wheel nut RRD000011 which has a smaller diam. shank. I think the Sport shank is around 22mm and the very early L322 is around 19mm.
L/H side Sport, R/H side very early L322 up to about 2004 I think.
Post #623145 Sun Mar 27 2022 11:14am
riverblanche
Hi,
you could either sell that one and buy another correct stud pattern wheel and there may not be much different in your costs, even cheaper than another set of wheel nuts and you dont have to carry them as spares
or if thats a really good tyre thats not ancient Question just pick up an alloy and swop the tyre over
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #623191 Mon Mar 28 2022 8:40pm
If it's a 18" rim Google RRC500261MNH might throw something up.
Post #623199 Mon Mar 28 2022 10:40pm
jk3528
Thanks for the replies
Post #623203 Tue Mar 29 2022 7:46am
