![]() | Home > Wheels & Tyres > Wheel ? |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9025 ![]() ![]() ![]() |
The top one isn't an RRS wheel. 2012 SDV6 - it's missing a couple of cylinders
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
Top pictures a early 18" 02-09 Fullfat wheel I think, ran those on my old P38.
The top one looks like a P38 wheel,the one I had the wheels looked the same & iirc the stud pattern is different. Andy.
Stud pattern is the same on the P38, Sport and Fullfat, it is the Wheel Spigot bore which is a different diameter on the P38, along with a smaller shank on the wheel nuts for the 02-09 L322. When I fitted early L322 wheels to my P38 I also used early L322 wheel nuts, and when I fitted Sport wheels I used Sport wheel nuts, along with a spigot ring reducer for both the L322 and Sport wheels.
jk3528 Member Since: 30 May 2021 Location: stoke on trent Posts: 75 ![]() ![]() |
Ok so will it fit with different wheel nuts ? |
I assume the Sport wheel nut shank diameter is to large to fit locate in the hole in the rim, if it is a very early L322 rim you will probably need wheel nut RRD000011 which has a smaller diam. shank. I think the Sport shank is around 22mm and the very early L322 is around 19mm.
If it's a 18" rim Google RRC500261MNH might throw something up.
Thanks for the replies |
