Home > Maintenance & Modifications > Sport 2015 Brake fluid leaking into Handbrake Actuater
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Hi lads sorry haven’t posted for a while . I updated to a 2015 Sport about a year ago. I appear to have Brake Fluid leaking into the Handbrake Caliper Actuators. Has anyone had this problem and advise me on the work required to repair. Thanks Jock🤔😞
Post #622581 Tue Mar 08 2022 8:32am
Kevin-t
I am NO mechanic Jock.
Just a thought Whistle Whistle Whistle
Could it be these that's gone....
https://www.rrsport.co.uk/forum/topic55302...rake+pipes
Just a thought.... Rangerover Sport 2016 4.4 sdv8 A/B loire blue.
Post #622584 Tue Mar 08 2022 10:06am
Tyrefitter
That part of the pipe doesn’t usually corrode like the other part,that looks like it just needs the fitting that goes through the pipe needs nipping up or the copper washer (they have 2,one either side of pipe)could need replacing.
First thing I would do is get some brake & clutch cleaner,clean it up & get something or someone to hold the brake pedal down & see if you can see where it’s weeping from.I doubt it has done any harm the the park brake actuator.
Or on the other hand,has is recently had any work done on the brakes & whoever did it didn’t clean them. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #622595 Tue Mar 08 2022 1:53pm
Jock 77
Hi Tyrefitter
Thanks for the reply. I will try and clean them both off tomorrow and pinpoint the leak. I have spent most of the day running around trying to find out and most were saying Calipers are quite bad for the Actuator seal into Caliper failing.
Also Calipers seem very hard to get if required and expensive.
Definitely worth a try cleaning and and fingers crossed it's not the Caliper ,but I am never that lucky. Thanks for th reply will let you know how it goes.
Cheers Jock Sad
Post #622618 Tue Mar 08 2022 8:01pm
Jock 77
Hi Tyrefitter
Just an update caliper seal definitely leaking into the Handbrake Motors. So looking into getting them changed.😞
Post #622714 Fri Mar 11 2022 5:13pm
