Home > General > Handbrake use? |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 897 |
You should use the handbrake especially on a hill. Not so much on flat as this is all that is stopping your car from rolling away if in Park. This is a Ford but all basically the same.
Thu Feb 24 2022 2:58pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
I'm in the "use it or loose it" camp.
Thu Feb 24 2022 6:55pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Ours gets used every time and serviced every other service. 2006 2.7 TDV6 HSE in Cairns Blue. |
Thu Feb 24 2022 8:36pm |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 |
Absolutely use it, just using it for an mot is asking for trouble Joined the X5 45e club
Fri Feb 25 2022 6:29am |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 478 |
Use it all the time. Just serviced and adjusted the shoes a few weeks ago. The lever on the right rear was seized so had to address that. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Fri Feb 25 2022 7:18am |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 409 |
Ditto the 4 entries above. Barrie.
Fri Feb 25 2022 7:33am |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 220 |
Use it or lose it was the advice from my indie. |
Fri Feb 25 2022 7:56am |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 402 |
The park brake on my 2010 TDV8 activates automatically when engine is turned off even if fthe transmission is in neutral.
Fri Feb 25 2022 3:51pm |
LesW Member Since: 30 Oct 2021 Location: Pays de la Loire Posts: 56 |
Quitting, that's one I've not heard of in a good while. It's actually the offence of leaving the engine running in an unattended vehicle as it happens. Nowt to do with handbrakes! 2015 RRS HSE Dynamic 3.0 SDV6 2015 Aston Martin Vanquish 2010 Jaguar XFR Le Mans 2001 Volvo V70 |
Fri Feb 25 2022 4:55pm |
Have a look at the Road Vehicles (Construction and Use) Regulations 1986, s107-(1).
Sat Feb 26 2022 8:48am |
Fair play. I guess in the old days we normally had manual cars, so yes, handbrake was the normal practice.
Sat Feb 26 2022 8:59am |
No worries, you too |
Sat Feb 26 2022 1:13pm |
DirtBuddha Member Since: 12 Jan 2022 Location: West Sussex Posts: 28 |
Few years ago an LR specialist told me to always engage the parking brake and also lower the air suspension when parking up.
Sun Feb 27 2022 9:10pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
I use my EPB every time. If the vehicle is serviced correctly, it should be cleaned and adjusted as part of the service and so should be trouble free.
Sun Feb 27 2022 9:34pm |
