![]() | Home > General > Handbrake use? |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 913 ![]() ![]() |
You should use the handbrake especially on a hill. Not so much on flat as this is all that is stopping your car from rolling away if in Park. This is a Ford but all basically the same.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
I'm in the "use it or loose it" camp.
Ours gets used every time and serviced every other service. 2006 2.7 TDV6 HSE in Cairns Blue. |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
Absolutely use it, just using it for an mot is asking for trouble Joined the X5 45e club
Use it all the time. Just serviced and adjusted the shoes a few weeks ago. The lever on the right rear was seized so had to address that. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Ditto the 4 entries above. Barrie.
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 221 ![]() ![]() ![]() |
Use it or lose it was the advice from my indie. |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
The park brake on my 2010 TDV8 activates automatically when engine is turned off even if fthe transmission is in neutral.
LesW Member Since: 30 Oct 2021 Location: Pays de la Loire Posts: 73 ![]() ![]() |
Quitting, that's one I've not heard of in a good while. It's actually the offence of leaving the engine running in an unattended vehicle as it happens. Nowt to do with handbrakes! ![]() 2015 RRS HSE 3.0 SDV6 2015 Aston Martin Vanquish 2010 Jaguar XFR Le Mans |
Have a look at the Road Vehicles (Construction and Use) Regulations 1986, s107-(1).
Fair play. I guess in the old days we normally had manual cars, so yes, handbrake was the normal practice.
No worries, you too |
DirtBuddha Member Since: 12 Jan 2022 Location: West Sussex Posts: 28 ![]() ![]() ![]() |
Few years ago an LR specialist told me to always engage the parking brake and also lower the air suspension when parking up.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9010 ![]() ![]() ![]() |
I use my EPB every time. If the vehicle is serviced correctly, it should be cleaned and adjusted as part of the service and so should be trouble free.
