Home > Technical > RRS 2011 turbo (inlet valve) issue - help needed |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 |
https://www.rrsport.co.uk/forum/topic55513.html
Mon Jan 31 2022 8:06pm |
MallorcaNick Member Since: 03 Jan 2021 Location: Mallorca Posts: 50 |
Thank you. I did read that (I searched for a long time) but it's different to what I'm asking. I think |
Mon Jan 31 2022 8:34pm |
Are you sure that’s the correct DTC? I’m not seeing anything in the service manual for P2202-77. There is P22D2-77, which is in the exact same diagnosis area as the issue I linked, in fact it’s the DTC just before it with almost the same diagnosis procedure (stuck open vs stuck closed) and can be caused by the same issue. Before dropping money on parts I’d look at that vacuum line.
Tue Feb 01 2022 6:20am |
This is incredibly helpful. Thank you so much.
Tue Feb 01 2022 9:02am |
Hi again,
Tue Feb 01 2022 9:04am |
In that link I posted they point out a common problem is a vacuum line coming undone. If this is in fact the problem it’s a simple and easy fix once you find the line and reattach it. That’s where I would be looking first. If that’s okay then move on.
Tue Feb 01 2022 11:23am |
I wish I could buy you (and many others on here) some beers! You're so helpful.
Tue Feb 01 2022 4:32pm |
No worries. Hopefully it’s a small easy fix. At this point you know the worse case scenario which is repairing the inlet valve. Best case the vacuum line is off and it’s fixed quick. The main thing is knowing, shops hate educated customers. I’m going to PM you a couple links I think you’ll find very useful. These are my first stop when things don’t seem right with my car. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Tue Feb 01 2022 7:39pm |
Scotty1980 Member Since: 08 May 2022 Location: Somerset Posts: 30 |
Hello everyone.
Fri Sep 16 2022 7:56pm |
It was one of the manifolds, which I got changed but then needed the other one done a few months later. |
Sat Sep 17 2022 7:29am |
