![]() | Home > Maintenance & Modifications > Impact wrench recommendations |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 ![]() ![]() ![]() |
Which ever you decide on you will almost definitley still need a manual one to give accurate torque settings, not cheap but best not to skimp when things like wheel bearing etc are being done. |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
either milwakiee or makita I use both and can't falt them |
I've recently bought a Makita DTW300Z after a lot of delibration over different models. It appears to be a great unit although I haven't used it in earnest yet. Plenty of torque, brushless motor and compact size.
Iomegas Member Since: 15 Nov 2020 Location: Newcastle Upon Tyne Posts: 213 ![]() ![]() ![]() |
Thanks for the advice folks |
Milwaukee 18 volt fuel,,ive got one & cannot recommend it enough,10x better than the Snapon one I have,in fact I’m going to sell mine as I no longer need it now I’ve closed my garage.Also with the Milwaukee it has 4 different torque settings,one being 130nm which is what most wheel nuts are torqued to,but I always check afterwards with manual torque wrench just in case. Andy.
Hi thanks for information how old is the one your selling and any idea on price your looking for . |
Mine is about 18 month old & has 2x 5ah Li-Lon batteries,,charger & case & im after £200 Andy.
