Home > Technical > New battery? And if so, which one!
MartinsTDV8
Scotland 2007 Range Rover Sport TDV8 HSE Buckingham Blue
I have been suffering from a battery drain recently. I had thought this may be linked to my BAS supplied FBH remote system. Or the loose positive terminal?
So whilst working on the car today I plugged in my IIDBT tool and the following faults were identified;-
U0073-88 (2C) Control module communication bus off - Bus signal/message failure - bus is off
( on 21-12-2021 12:49:56 at 227730 km )
Auxilary Heater
B1D33-92 (2E) Flame interruption during normal operation - Component failure - performance or incorrect operation
U1A44-6C (2E) Fuel level
Body Control
B1B70-81 (2Cool Local interconnection network bus circuit 2 - Bus signal/message failure - invalid serial data received
( on 03-12-2021 12:17:37 at 227150 km )
B1B93-3A (2F) Seat recline motor speed/position sensor - Frequency modulation/pulse width modulation failure - incorrect, has too many pulses
( on 03-12-2021 08:25:05 at 227150 km )
B1C99-15 (6C) Right corner lamp circuit - General electrical failure - circuit short to battery or open
( on 05-12-2021 02:27:23 at 227150 km )
B1D00-15 (6C) Left low beam circuit - General electrical failure - circuit short to battery or open
( on 21-12-2021 12:49:50 at 227730 km )
Engine TDV8
U0138-00 (2Cool Lost communication with all terrain control module
U0405-81 (2Cool Invalid data received from speed control module - Bus signal/message failure - invalid serial data received
U0405-85 (2Cool Invalid data received from speed control module - Bus signal/message failure - signal is above allowable range
HeadLight
B1D67-91 (AF) Right headlamp power module - Component failure - parametric
( on 12-04-2021 04:27:08 at 227748 km )
B1D69-01 (2Cool Right headlamp swivelling feedback sensor circuit - General failure information - general electrical failure
( on 21-12-2021 12:38:47 at 227724 km )
Instrument Pack
U0132-87 (2Cool Lost communication with ride level control module - Bus signal/message failure - missing a message
U0182-87 (2E) Lost communication with front lighting control module - Bus signal/message failure - missing a message
U0159-87 (2E) Lost communication with parking assist control module - Bus signal/message failure - missing a message
B1A87-68 (2Cool Battery disconnection/electronic control unit reset - Algorithm based failure - event information
Parking Brake
U0122-87 (ACool Lost communication with vehicle dynamics control module - Bus signal/message failure - missing a message
( on 17-12-2021 17:43:53 at 227592 km )
C1A00-16 (ACool Control module - General electrical failure - circuit voltage below threshold
( on 06-12-2021 07:09:33 at 227168 km )
U0155-87 (ACool LCD Gauge Communication Lost - Bus signal/message failure - missing a message
( on 08-12-2021 03:19:53 at 227216 km )
Steering Angle
U0300-55 (2Cool Internal control module software incompatibility - System programming failure - is not configured
( on 12-04-2021 04:26:43 at 0 km )
Suspension
U1A13-87 (2Cool Lost communication with all terrain control module - Bus signal/message failure - missing a message
( on 07-12-2021 14:02:01 at 227204 km )
Transfer Case
U0138-86 (2Cool Lost communication with all terrain control module - Bus signal/message failure - signal is invalid
Transmission
U0155-87 (6D) LCD Gauge Communication Lost - Bus signal/message failure - missing a message
Ventilation
B1B74-00 (2F) Front foot-defrost mode stepper actuator
( on 03-12-2021 12:15:32 at 227156 km )
B1B75-00 (2F) Front foot-face mode stepper actuator
( on 03-12-2021 12:15:33 at 227156 km )
It suggests to me, despite it seeming to be okay, to be the battery that’s at fault? I currently have a Bosch 95Ah 800a battery fitted.
I am looking at a Bosch S5 110Ah as a replacement- what are your thoughts?
Ps all the faults cleared and have stayed off so far , fingers crossed Thumbs Up
The battery is 3 years old, and the car is a 2097 TDV8 without stop-start. Previously owned 1999 Disco 2 TD5
Disco 3 HSE TDV6 2007
Gone 2007 TDV8 RRS1 in Buckingham Blue.
How do know if the knocking at the front has been sorted?
You can hear the knocking at the rear better
Post #620182 Tue Dec 21 2021 2:41pm
The battery drain might be the rear glass hatch switch. They are a known corrosion issue. Easy enough to replace too, which is good news.
Unless you can track the battery drain issue down, replacing the battery won't really help - the new one will also be subjected to draining.
Have you checked the alternator output with the engine running? If that's not fully healthy, the battery will struggle over time too. 2012 SDV6 - it's missing a couple of cylinders
Post #620192 Wed Dec 22 2021 10:02am
MartinsTDV8
Re: New battery? And if so, which one!
RR - The Alternator has been tested and seems healthy. But it could be the rear tailgate as the new number plate lights that I fitted recently have already started to suffer. Looks like water may be in there somewhere Big Cry
And thats how I will be spending my day Censored
Thanks pal
M.
Auxilary Heater
Body Control
Engine TDV8
HeadLight
Instrument Pack
Parking Brake
Steering Angle
Suspension
Transfer Case
Transmission
Ventilation
Post #620193 Wed Dec 22 2021 10:49am
Dave B
Loose positive battery clamp will show similar faults.
Dave 2010 3.6 TDV8 HSE (Gone)
Post #620196 Wed Dec 22 2021 2:36pm
