Home > Technical > Air suspension rebuild
Simon_CSK
I have replaced the air tank and pump on an Overfinch RR Sport.
I am aware that the software can re-pressurise and depressurise the system.
Is it possible to re-pressurise the system without the software and if so how? Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #620110 Sun Dec 19 2021 1:22pm
DrDeAtH
Just run the compressor for no more than 5 minutes. Then let it cool for 5 minutes,
Do this a few times until the system has filled
Post #620158 Mon Dec 20 2021 11:27pm
Simon_CSK
Great thank. Will do that but defohave a leak and think I know where it is. Current cars
Range Rover CSK
Discovery 3 HSE
Post #620169 Tue Dec 21 2021 7:03am
Disco_Mikey
The compressor will shut off if it gets too hot
And a good system should be able to lift the car of the bump stops to normal ride height, and fill an empty reservoir within 5 minutes
As for the original question, it can be done via diag gear Thumbs Up
Post #620172 Tue Dec 21 2021 8:14am
Simon_CSK
Thanks Mikey am goimg to crawl under it today. I am getting a fault code A1C20-64 an suspect I have damaged the connection to the tank as it was a pain to connect.
Will set it on stands to fill. Current cars
Range Rover CSK
Discovery 3 HSE
Post #620174 Tue Dec 21 2021 8:24am
