Home > Technical > Air suspension rebuild |
DrDeAtH Member Since: 27 Jan 2020 Location: Herts Posts: 26 |
Just run the compressor for no more than 5 minutes. Then let it cool for 5 minutes,
Mon Dec 20 2021 10:27pm |
Simon_CSK Member Since: 21 Dec 2020 Location: East Ayrshire Posts: 70 |
Great thank. Will do that but defohave a leak and think I know where it is. Current cars
Tue Dec 21 2021 6:03am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
The compressor will shut off if it gets too hot And a good system should be able to lift the car of the bump stops to normal ride height, and fill an empty reservoir within 5 minutes As for the original question, it can be done via diag gear |
Tue Dec 21 2021 7:14am |
Thanks Mikey am goimg to crawl under it today. I am getting a fault code A1C20-64 an suspect I have damaged the connection to the tank as it was a pain to connect.
Tue Dec 21 2021 7:24am |
