![]() | Home > General (L494) > Faulty EPB is it the weather or coincidence |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
Suggest you dont use it at all. Until repaired / replaced. I’ve changed 3 in the last 3 years.
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 180 ![]() ![]() ![]() |
The OP has a L494, I think the manual release is only for L320 variants, the release procedure for the L494 is remove the parking brake actuators from the caliper and manually wind the pistons back if I recall correctly.
By manual release; I mean removing the cover of the epb.
