Home > General (L494) > Faulty EPB is it the weather or coincidence
PC76
Hi all,
I’m currently in Switzerland and it’s been down to -18. My EPB has thrown its toys out of the pram and I’m getting the amber
Warning re park brake applied and not functioning correctly but won’t calibrate.
I have tried the IID tool but no luck…
Will I just need to wait for warmer climes to sort it self? 2015 4.4 Autobiography
2010 3.0 HSE 162K - Gone
Post #619861 Thu Dec 09 2021 3:15pm
PauloAmore
Scotland
Suggest you dont use it at all. Until repaired / replaced. I’ve changed 3 in the last 3 years.
When it jams on you’ll be stuck.
But it can be manually released; by removing the cover etc etc. 2022 P440e AB
Post #619871 Thu Dec 09 2021 10:14pm
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
The OP has a L494, I think the manual release is only for L320 variants, the release procedure for the L494 is remove the parking brake actuators from the caliper and manually wind the pistons back if I recall correctly.
I stand to be corrected however as I have never had this issue!
regards
Mike
Post #619874 Fri Dec 10 2021 8:43am
PauloAmore
Scotland
By manual release; I mean removing the cover of the epb.
On the wheel hub.
And you’re right; there is no manual release on a L494.
Sorry if I created confusion.
P 2022 P440e AB
Post #619885 Fri Dec 10 2021 8:51pm
