Home > General > Fuel Burning Heater not working.
joboco
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Java Black
Help required with fuel burning heater. I have the timed options on the screen but when I set the timer nothing happens. I don't have an option for manual heat or manual vent (greyed out). I changed the number 2, 5 amp fuse, still nothing. Please look at the attached pictures and give me your opinions as what to try next.
Post #619609 Mon Nov 29 2021 2:15pm
joboco
Update. I now have the manual controls illuminated but still nothing working. If I had any hair I would pull it out in frustration.
Post #619613 Mon Nov 29 2021 4:48pm
RugHead
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
I think for the parking heater to kick in, the battery has to be above a certain voltage and there has to be at least a quarter of a tank of fuel, so if the battery or fuel are low it will not fire up, also I think if the heater fails to fire a certain number of times it goes into a lock out mode which can be reset with the GAP tool, does the heater fire up when you start the vehicle at low temps of 6 Deg and below ?, There's a full section on the fuel burning heater on the disco 3 forum.
Post #619616 Mon Nov 29 2021 5:08pm
joboco
Thanks for the reply. I have a full tank of fuel ambient temp -2. It doesn't work on timer or manual heat. It doesn't work with or without the engine running or whatever the temperature is.
Post #619617 Mon Nov 29 2021 5:17pm
joboco
Yet another update: the heater is now working. After advise from a first class indi (Strathearn Engineering Perth) I found more settings on my Gap lld for the heater and cleared all codes. All is now well.
Post #619618 Mon Nov 29 2021 6:04pm
riverblanche
Hi,
what was the cause though Question
had it locked out from previous none fire events or something else.
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #619639 Tue Nov 30 2021 6:45pm
